So my windows and my blower motor for the interior fan aren't working. If I pop open the relay, and push it closed, and then use the window or blower it works fine. So my relays aren't energizing. Shouldn't these ones energize when the key is turned to on? Also, I don't have a low beam relay, looks like a funky one. Anyone know a part number?
I swapped in a healthy m20 and just got it running. So, Plugs I should check? Bentley doesn't show a whole lot about electricity to the relays, (I probably need to look closer.)
edit: After looking more carefully at the bentley, there are a couple plugs under the left side of the instrument panel, (lower panel is still off on my car) so I need to hop in and check those,
Thanks guys.
Thanks guys.
