E30 wheel spacer
  • Calvin Tan
    • Nov 2004
    • 55
    E30 wheel spacer
    Dear friends,
    I'm considering getting a wheel spacer for my car. Can a 8mm wheel spacer uses the old bolts and BMW wheel bolt lock?
    Best Regards,
    OO=[][]=OO
    Calvin Tan
    Eurocar Motorsport - automobile Technik
    www.EurocarMotorsport.com
    www.geocities.com/calvintan_e30
  • Jordan
    • 12916
    Any spacer requires longer lugs.
    Here is the rule (although I would apply it to wheel lugs/studs at your own risk)
    If the length of engaged threads is equal to 1/2 the diameter of the threaded bolt, maximum strength has been achieved.
    For our lug bolts, thats about 3.5-4 threads. I like to make sure my lugs are threaded in to the back of the hub, if not 1-2 threads past that. Too much more then that will result in the end of the lug striking the ABS sensor in the front, and striking ebrake hardware in he back.
    https://mtechniqueabs.com/
