Okay, this problem has been plauging me for some time now. Ever since I did the motronic 1.3 swap I've never had good throttle response at idle. I have the 173 ecu and it helped a little. Basically what happens is if I go to snap the throttle, or even just blip it a little it nearly dies, then 1 second later it will try and rev up. If i rev it off of idle curicut and then snap it, it has great response.
My ICV checked out okay on the ohm reading (40 ohms across the terminals) I have 11.5 volts at the center pin (I think its center, whichever is power) And then 6.5 volts between pin 1 and 2, and 2 and 3. The TPS is fine, and adjusted correctly. My instructors at school said it sounded like the TPS, and after i explained to them that my car doesnt have a variable TPS with a pot, they had me thinking it might be the AFM since the pot is in there. The board doesnt look to be in bad shape, but I suppose if it were to blame it would only be isolated to a small area, and id probably never see it.
Any suggestions?
Any suggestions?
