Standing water in cylinders
  • BlindWolf187
    • Sep 2011
    • 15
    If you saw this thread:
    then you know that my M62 block is dead, and I need a new one. A friend of mine (creator of the aforementioned thread) went to look at an E38 with a supposedly good M62, but what he found was an M62 stripped to the heads and block with rusted cams and cylinders full of water. All I wanted was the block.
    Does anybody have any experience with water corrosion on alusil or aluminum? Has anybody tried to remove a rusted piston ring from a cylinder without damaging the cylinder walls?
    We suspect the block may have been in this condition for up to a month. I'd ignore it, but on the off chance the block is salvageable I think I can get it for next to nothing.
  • TobyB
    • 5296
    I'd keep looking...
    t
    • Massimo
      • Jan 2008
      • 3207
      Originally posted by TobyB
      I'd keep looking...
      t
      This.
      • z31maniac
        • 17566
        Even if you got it for free, you're still going to need to PAY a machine shop for proper testing/fixing.
        www.gutenparts.com
        • Massimo
          • Jan 2008
          • 3207
          In all seriousness ask a machinest about dry sleeving your old block might be a better option.
