Can't Lock My Car!
  • swolfe
    • Jul 2012
    • 32
    Can't Lock My Car!
    I just got my first e30 about a week ago, an '88 325is. I've been loving it, and this site has been a real help too.
    I have started to have trouble with my locks. My car came with one BMW key (the kind with the LED in it) and two non-BMW spares. I put one of the no-name keys on my ring and found that I couldn't lock my door. I thought maybe it was the key.
    My BMW key seems to work intermittently. I wasn't able to get the car to lock today. It worked yesterday, but not the day before. Strange. I can lock my doors manually.
    I'm also having problems where my electric mirror adjustments only work intermittently.
    I was told it might be the electrical connector to the door. Does this sound plausible, and how do I actually check it? I tried searching for this problem but mostly found people with broken actuators, where they couldn't even lock their doors manually.
    Thanks.
  • bernzpeed
    • 3917
    take the switch out and use a sandpaper on the contacts.
    spray the lock cylinders WD40.
    89 E30 S52
    Transaction Feedback.
    • dannyyisntt
      • 3141
      Just don't leave anything expensive or valuable in the car
      • Dsun
        • Jul 2011
        • 371
        wiggle the key when its turned to lock.
        When i normally turn to lock on my car it does not lock, I give it a nice wiggle and it locks...does it everytime, i guess its a connection issue, too lazy to take it out to fix
        Had a smooth purchase transaction with me?
        Please share your feedback
        • bmwguy325is
          • May 2011
          • 1263
          Can you lock the doors from the trunk?
          sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
          The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
          • swolfe
            • Jul 2012
            • 32
            Lubed the doors. Wiggle doesn't work. It seems that the trunk and passenger door work and the driver doesn't. (Though they didn't work this afternoon...)
            • bmwguy325is
              • May 2011
              • 1263
              The drivers lock sensor often wears out. Maybe your central locking is on the fritz? I locked my car from the trunk for a year before I got keyless
              • peytonracer4
                • May 2011
                • 524
                there's a shaft in the drivers door that the lock hits when you turn it clockwise.
                on my first e30 the shaft on the lock cylinder was broken off. i had to buy a rebuild kit and rebuild my lock cylinder. this fixed it.
                open up your door and watch things move when you lock/unlock it. you'll figure out what's wrong quickly
