throttle position sensor swap
  • gone002
    • 879
    anyone have any tips for changing the TPS out before i go and pull it apart? any thing i need to know about keeping everything all lined up?
    thanks in advance
    bimmerboltsandparts.com
    bring back the neeked broads!!!
  • der affe
    Technical
    • Dec 2005
    • 8452
    Yea, it's a bitch with ITBs. Just pull them to change it out.
    • gone002
      • 879
      ok then!! thanks
      • Gregs///M
        • Mar 2012
        • 2459
        Use a multimeter on continuity setting to test the contacts after installation.
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
        • CarsSuck
          • Oct 2005
          • 968
          I used a little phillips bit in a 1/4" socket in a tiny ratchet to remove/install.
          --Will
          • 5Toes
            • 9836
            I did it, and the new one you dont have to pull the cover to pop it on (its impossible to actually)
            The click will be very distinct
            • gone002
              • 879
              i guess its more straight forward than i had thought...i was not sure if i had to "zero" the valve inside or something...thanks again guys...ill do it in the am and report back if it fixes my idle issue.
              • 5Toes
                • 9836
                Easy way to check is just let car idle and jump the pins on the connector the middle and the one that plugs into the right side of the connector
                • gone002
                  • 879
                  just got back from buringman and i still have not put the MFer in ...gotta get on it
                    When you install the new TPS, adjust it so that the idle switch closes when the throttle arm is 1mm off the idle stop screw.
                    • gone002
                      • 879
                      thats what i needed to know!! thanks buddy
                      sometimes this site is worth a fuk!!
