Diagnosis plug wires at instrument cluster?
  • kameleon
    • May 2011
    • 288
    Here's a weird one....
    I have a Toyota 3SGE Beams engine converted E30 (1989 318i), and due to the use of the Toyota engine wiring i no longer have the diagnosis plug etc in the engine bay.
    As i am trying to keep the car looking stock even down to the instruments (everything works as it should atm) would like to still be able to reset the service lights.
    Can anyone help with plug and wires needed to jump to reset the lights? I have asked the guy who wired the car and he was no help at all, so it is now up to me to get this sorted.
    My thoughts are that if it eminates from the cluster i should be able to reset it at this point (providing the batteries are still ok)
    Any help is greatly appreciated.
    This is the conversion.
    What i am trying to fix
  • vpilarrt
    • Jun 2006
    • 2096
    Ground pin 22 in the blue connector on the back of the cluster (with the connector still attached to the cluster). Turn on ignition, but don't start the car. Wait 5 seconds. turn off ingition, remove ground.
    • kameleon
      • May 2011
      • 288
      LEGEND! will give it a go. Thanks for the speedy response.
      Ps. do you know the wire colour by any chance?
      • dnguyen1963
        • Nov 2011
        • 2649
        Just remove the LEDs from the SI board.
        • kameleon
          • May 2011
          • 288
          As i mentioned i am trying to keep all functions of the car as they were when it had the M40 fitted.
          • vpilarrt
            • Jun 2006
            • 2096
            White/blue
            • FLG
              • Sep 2011
              • 3165
              George graves offers a conversion, turns the SI lights into a voltage gauge....might be worth getting.
              Sent from my Galaxy Nexus using Tapatalk 2
              -Build http://www.r3vlimited.com/board/showthread.php?t=295277
              • Gregs///M
                • Mar 2012
                • 2459
                There is also a disconnect switch or jumper on the SI board itself. I believe this will remove power and reset service interval.
                This only applies to instrument clusters with coding chip on the front.
                Owner - Bavarian Restoration
                BMW and European Electronics Repair and Restoration
                www.BavRest.com
                My Feedback Thread
                Our Facebook!
                Follow our Instagram!
                • george graves
                  • 19996
                  Thanks for the plug FLG -The Si lights are there just to remind you to take your car to the dealer....so you can remove the board and someone suggested, or (a small plug for myself) you can convert it to a voltmeter.
                  Originally posted by Matt-B
                  • kameleon
                    • May 2011
                    • 288
                    Thanks everyone.
                    For me i like the novelty feature of keeping as much of the stock vehicle as possible (even if it is a bit if a wank factor) hopefully it will all reset.
