Well i noticed the water temp to rise while i had to wait like 30 minutes in line to get my cars emissions tested. I would have turned it off but i had to pull forward every couple minutes. it didnt go much higher then normal so i didnt think anything of it. As the car is getting tested i see him go through the gears on the rollers. Then do it agian which is a bad sign becasse it means i didnt pass the first time. SO he goes through 1st 2nd and 3rd like 4 more times and for some reson it didnt pass becase the THC was 1.6 and the max was 1.2. So im pulling out on to the road and i notice the temp gauge was starting to reach the red so i quick turn on the heat full blast and it goes back to normal in like minute then continues to go to a little below normal. I drive a couple more miles to the tire place i was going and get out and the engine seemed to feel as hot as it always does. The oil and coolant seemed ok but i need to look at them under better lighting. I know the heads on these are very easy to warp, but do you think the engine should be ok?
and i drove around for a while and the car passed with .95 HC
