A/C wiring messed up
  • VAE30FTW
    • Jun 2011
    • 171
    My A/C for some reason doesn't work.
    I removed the plug above and tried jumping it. Everything came on but the jumper got hot quick! any reason why? Could the aux fan be short circuiting stuff out?
    ^that's some sort of ground loom I assume.
    H&R OE Sport Springs - Bilstein HD's - Kosei K1's ET27 - Toyo R888 - ZHP 5spd knob - BavAuto strut bar - DINAN Chip - E30 M3 Offset Bushings - Colgan bra - P-car daily
    It sounds like there is a short downstream of the slider switch. Use the wiring diagrams at http://wedophones.com/BMWManualsLead.htm to figure our where.
    • VAE30FTW
      • Jun 2011
      • 171
      I'll take a look and report my findings. doesn't look like fun...
      • VAE30FTW
        • Jun 2011
        • 171
        Well the brown and green wires are 12v. those are fine. then the white wire goes directly into the A/C switch.
        • VAE30FTW
          • Jun 2011
          • 171
          Well found the cause
          As you can see I closed the switch slider. I'll just place an inline 1.5amp fuse in there.
          The fix
          Disconnected the wire going to the alternator. Still need to test the a/c clutch for issues. Maybe the A/C diode is grounding out and faulty? Any thoughts?
          EDIT: I think it needs a new a/c clutch. What are my options?
