1991 121hp 325i?!
  • darvo
    • Dec 2010
    • 407
    1991 121hp 325i?!
    About a month ago I bought a 1991 325i coupe with manual transmission, I checked the cars paperwork and it says 121hp :evil: So I then checked a bmw vin decoder and in the specs it also says 121hp!! :hitler:
    Did these cars came in 91 with less hp than other e30-i years?
  • SmokeE30
    • 1730
    as fa as i know i cars that are us spec should be 167hp my 88 seta is 127hp and i think a standard 325e is about that 121hp, but no e cars were made in 91 so something is off there. is it a us spec car?
    Shawn @ Bimmerbuddies
    Bimmerbuddies LLC
    717-388-1256
    2971a Roundtop Rd, Middletown PA 17057
    bimmerbuddiesllc@gmail.com
    • darvo
      • Dec 2010
      • 407
      Yes, US spec.
      • Joseto_e30
        • Jul 2012
        • 16
        It´s a 325e then.
        • StealthiE30
          • Jun 2012
          • 491
          Whats your tachometer go to?
          IcWhatUdidThere
          • StereoInstaller1
            GAS
            • 22679
            Originally posted by Joseto_e30
            It´s a 325e then.
            Nope, no such thing after '88
            Closing SOON!
            Thanks for 10 years of fun!
            • TobyB
              • 5280
              Someone swapped the 318i for a 325 on your trunk. You're missing 2 cylinders...
              heh
              t
              • e30trooper
                • 11576
                pix of said engine
                • Jaxx_
                  • Dec 2009
                  • 1880
                  heh
                  t
                  i agree. m42 brah
                  • freeride53
                    • 11972
                    You have a 318is. Sorry, and you're welcome.
                    1983 Peugeot 505 STI
                    1992 Volvo 240 Wagon
                    • freeride53
                      • 11972
                      or maybe not ... the m42s were rated at 140
                      • e30trooper
                        • 11576
                        it could be a 325i with a dash swapped from a eta and they never swapped the vin? eta's had 121hp 171tq
                        • FLG
                          • Sep 2011
                          • 3165
                          A engine pic will clear up this mess also what does your tach red line at?
                          Sent from my Galaxy Nexus using Tapatalk 2
                          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                          • mkcman17
                            • Jul 2010
                            • 8240
                            your door tag will tell all. as ben said, if you're using the dash tag, it may have been swapped and not changed...pretty common.
                            b25s should run 167bhp. nuff said.
                            1989 LN106 Hilux / 3.0TD SFA
                            1974 2002tii / stock
                            2002 IS300 / 5spd LSD
                              If the chassis is a US 1991 it could be a 318is (140hp) or a 325i (168hp) assuming the original engine is in the car. The dash VIN plate isn't trustworthy as the dash could have been replaced. Since it is stamped into the metal the VIN on the forward edge of the cowl can be trusted. As to the engine in the car, a picture of the engine bay will allow us to narrow down the possibilities.
