Did a top end job about 3K ago and it was running great. A couple hundred miles ago it developed a very slight rough idle. In the past few miles things have deteriorated rapidly to the point were it will not idle at all. The OBDI shows no fault codes 1444. My under the hood Peake diagnostic reader seems to says it is the Lamda sensor but the check engine light is not on. Any ideas...please.
Help...my car will not idle... continued.
spark plugs look okay?'84 318i M10B18 147- Safari Beige
Turbo: 221whp/214ftlbs, MS3x flex @ 17psiComment
Idle problem continues...help!
Replaced boot between throttle body and airflow unit as it had some dry rot but no improvement. I can start the car and get the RPM up to the mid teens to keep it running but then the RPM slides down to around 500 RPM and eventually will be rough and stall. The consensus seems to say vacuum leak...anything specific to look at. Any chance a bad oxygen sensor can cause this as my under the hood diagnostic tool says that is a problem but the OBDI system does not.Comment
If the engine won't idle when cold, the O2 sensor can't be the cause. At that point the DME is in open loop mode and not using the O2 sensor data.
As far as intake leaks, the specific things to look at are where you see smoke leak out during a smoke test.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
if you're sure you got the right fuel line, yes.
Does the fuel pump whine at all?'84 318i M10B18 147- Safari Beige
Are you sure you have the gauge on the supply side? That is the hose that connects directly to the rail. The hose that connects to the FPR is the return line and will be a zero pressure.
If you have zero pressure in the rail, the engine won't fire or run at all.The car makes it possible, but the driver makes it happen.
Fuel pressure saga continued.
Clearly hooked up to the rail. I'm assuming there is a little pressure but it is quickly bled off when starting the car which only runs for a few seconds. Can't hear anything running from under the rear seat. Should I pull the rear seat and listen. Should I hear the pump when the car is not running? Is there more than one pump? I have replaced the fuel filter within the past 3K.Comment
