Blower only works on high
  • idickers
    • Sep 2011
    • 92
    I have a '91 318is, and the blower only works on high. I suspect that the rotary switch has failed. Is this fairly easy to replace?
  • reelizmpro
    • 9556
    resurface resistor coil pack contacts.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • idickers
      • Sep 2011
      • 92
      What's this?
      • Garageaholic
        Freestyle Fabricator
        • Dec 2005
        • 5204
        Replace resistor coil. $20 and make sure you get the correct one for early or late model 30
        Recent Rebranding!!
        E30 SM62/S62
        E30 M60 V8
        E30 M30 Big 6!
        Instagram.com/garageaholic
        Youtube.com/garageaholic
        • blunttech
          • 12850
          2 kinds Ian Magna and a bosch Magna has fixed wires Bosch doesnt
          sales@blunttech.com
          www.blunttech.com
          Like us on Facebook
          • idickers
            • Sep 2011
            • 92
            Thanks everyone. I was hoping to order before removing the resistor, but looks like I'll have to dig it out first. And my daughter was just getting used to working a/c ......
            Ian
            • fronton
              • Oct 2009
              • 1262
              Is there a way to get at the resistor pack without accessing the box from the engine bay?
              • idickers
                • Sep 2011
                • 92
                Steve, can I tell which resistor I need by VIN #, or do I have to dig out the resistor to make sure. It would be great to have the part before disabling the blower.
                • Jean
                  • 18228
                  no . unless you want to pull the dash, and pull the blower/ac box inside the car
                  • fronton
                    • Oct 2009
                    • 1262
                    ha, dash will be easier than pulling the engine!
                    • Wh33lhop
                      • 11705
                      Just buy an S50 so it will be worth pulling the engine.
                      (you shouldn't have to pull the engine, it will take some finagling)
                      paint sucks
                      • Jean
                        • 18228
                        Yeah, no need to pull the engine. If anything, some pull the intake manifold to do the blower fan and/or wiper hardware
                        • fronton
                          • Oct 2009
                          • 1262
                          If I had an M20 I wouldn't need to pull the engine. My "problem" is that I have an s38 and its a little less accommodating against the firewall. Note sig. These are first world problems.
                          • E30Gus
                            • Jun 2008
                            • 781
                            When this happened to me, it ended up being the brushes in the blower motor wearing out and not the resistor.
                            • idickers
                              • Sep 2011
                              • 92
                              Would bad brushes cause the motor to run only on the high setting? I would have thought the brushes would have affected all speeds.
