Eta 2.93 LSD into IS 3.73 case
  • dsphil
    • 495
    My IS LSD is making noise. Can I swap the LSD from my eta into my IS differential case keeping the 3.73 ratio without problems? what other LSDs will working with the 3.73 or all e30 LSD are the same? I can't seem to find a good 3.73 LSD differential and since the eta has been up on floor jacks for month now maybe I'll take it out and swap it for now. If I can find a good 3.73 that would make the job easier.
    327is
    325es
    325es
    318is
    Fiesta ST
    E46 M3
  • mr.vang
    • 4371
    i don't think you can, since your combining two different gears ratio. although you can just swap in a whole 3.73 in but it will suck on the highway. i swap in a 3.25 on my eta and highway driving is not so bad. try to find a 3.25lsd, e28 535is came with it.
    • bmwguy325is
      • May 2011
      • 1263
      What is the noise your old diff is making?
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • dsphil
        • 495
        I am referring to the LSD unit itself. The LSD unit itself has no ratio. I should have ask if the parts and LSD is interchangeable between the 2.93 and 3.73 differential.
        327is
        325es
        325es
        318is
        Fiesta ST
        E46 M3
        • mr.vang
          • 4371
          don't the lsd unit have gears inside?
          • dsphil
            • 495
            Tire squeak on tight turns and clunk noises shifting When I jacked up the rear and spin the wheels they both turn like it should but there are plays. I compared to the known good differential on the eta es.
            327is
            325es
            325es
            318is
            Fiesta ST
            E46 M3
            • dsphil
              • 495
              Yes it has gears to differentiate or to lock the two axle using clutches, but has nothing to do with gear ratios. Correct me if I am wrong. I hope I got all the terms corrects.
              327is
              325es
              325es
              318is
              Fiesta ST
              E46 M3
                • 34844
                I dont think the low ratio carier works with high ratio gears.
                  The description of the problem sounds more like wear in the differential bearings and gears than wear in the clutches. The bearings and clutches can be replaced with the parts costing about $500-600, but rebuilding a differential isn't a trivial task as clearances and pre-load must be properly set. A decent used 3.73 LSD can usually be had for $250-300.
                  • dsphil
                    • 495
                    I want to replace or swap this from my eta Es into my IS. Are they interchangeable?
                    327is
                    325es
                    325es
                    318is
                    Fiesta ST
                    E46 M3
                      Well sort of. You'll have to re-shim the output shaft bearings for correct end play and and probably will need to re-shim the pinion shaft for correct mesh, which also means setting correct pre-load. You might as well just rebuild the 3.73 diff you have if you are going to that much trouble. Fitting this in is 80% of the way to a full rebuild.
                        • 34844
                        like I said, I don't think you can use a low ratio carrier with a high ratio ring and pinion.
                        • dsphil
                          • 495
                          Looks like is a don't do it kinda answer to my question. Thanks guys.
                          327is
                          325es
                          325es
                          318is
                          Fiesta ST
                          E46 M3
