Black coolant reservoir...
    • 34827
    it looks nice but then you can't see the coolant level. same with painting over the fuse box.
    Too bad they're like $95 new. I need a new one too.
    • EyExR
      • Jan 2011
      • 956
      I painted mine and it looks great. I do worry a little about not seeing the level but I'll just fill it to overflowing every now and then...
      BTW - best paint to use is Krylon Fusion for plastic. I did mine in satin black. Washer fluid tank too. Looks great and there's no way this stuff is flaking off - the paint bonded incredibly well.
      I tried the bleaching method on my washer tank but it just wasn't clean enough for me...
      Some pics as I was reassembling my bay:
      My 325iX DIY Threads:
      Front Wheel Bearing Replacement
      325iX Rear Subframe Bushings and MUCH more w/pics!
      325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
      • ohthejosh
        • 4963
        Maybe masking of a small portion of the tank before painting it would solve the issue with not being able to see the level. But since its all black im not sure if that would even work really.
        Ross, maybe if you do paint your reservoir you can mask off an area vertically to try and see if you are able to read the levels. An area no wider than a No 2 pencil would be ideal I think.
        SO MUCH MORE TO DO!!
        IG: ohthejosh
        LEGIT CHECK ME BRUH
        BUYER FEEDBACK THREAD
        • AndrewBird
          The Mad Scientist
          • 11897
          RIT fabric die will die the plastic any color you would like. I've done it on several other items made of similar/the same plastic.
          • 5Toes
            • 9836
            Can you bleach the tank on a m42 or e34 radiator??
            • straight6pwr
              • Sep 2004
              • 3450
              looks good, but i've never seen the paint hold very well on any of the e30 engine plastic bits. always ends up flaking off.
              • peytonracer4
                • May 2011
                • 524
                what paint do you have on your valve cover gasket? is it really that matte in person?
                • stamar
                  • Apr 2011
                  • 1362
                  that delphin with the m50 is so tight.
                  • AndrewBird
                    The Mad Scientist
                    • 11897
                    Bleach really does't work all that well. The reason the plastic yellows it not because it is stained, but because the plastic chemically changes over time and turns yellow. Cleaning the surface of the plastic isn't going to change the plastic itself. You will just end up with clean, yellowed plastic.
                    Dying them, like I said before, will color it into the plastic, not just a surface coating like paint. Here is a picture of my fuel tank on my Go-Ped when it was blue:
                    Fuel wasn't able to "wash" the color off, so I'm sure it would work fine for coolant/washer fluid.
                    • CW325
                      • Jul 2011
                      • 1434
                      If you were to dye it black it would probably come out purple at first. I would dye it a dark color first and than black.
                      • AndrewBird
                        The Mad Scientist
                        • 11897
                        I did a tank black as well and it came it great. The longer you leave it in, the darker it gets.
