failing fuel pump power connector: where to get new one?
  • static
    • Oct 2005
    • 501
    Hi all
    tried searching to no avail. Is there a replacement for the fuel pump power connector? (i.e not the sender one) - mine is failing, the tab that holds it in place is broken and it causes power cut out once in a while (which kinda sucks)
    anyone knows where to get a new one that'd fit the original prong?
    or does anyone have a piece of old harness that has that connector in good operating condition?
    Thanks
  • redsubdivisions
    • Feb 2011
    • 1762
    Repair it. shouldn't cost you more than a few dollars with a new plug housing and terminals from the local dealer.
    1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
    2012 Passat TDI - DD Duty
    2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
    • 5Toes
      • 9836
      Mine too, part number?
      Is there a diy on how to replace the pins?
      • 5Toes
        • 9836
        bump
          • 34844
          1) www.realoem.com/bmw/
          2) www.blunttech.com
          3) cut old pins off
          4) crimp new pins on
          5) plug into fuel pump...
