My friend's ETA had an an idle problem, until now. He had bought a rebuilt Bosch alternator. Bosch is a high-end, OE supplier. However, their re-manufactured alternators come with the casings re-painted. As well as no pulley. No biggy, until the paint.
You will find that there are 3 power connections, and the smallest of the 3, grounds <some shit to do with> the idle control valve and whatever else. It grounds to the casing, which was painted over...
His car ran like a douchetard, until we got it back here and sanded down the grounding point to bare metal, then re-attached the small ground wire. Car runs smooth as ever now. :) The ICV was not receiving proper voltage signals because it wasn't grounded properly, as other sensors probably weren't either.
This is something that no-one ever checks, so do it if you're having problems. The airbox is easy to remove, and underneath you will find the alternator -- it's easy to access on both "e" an "i" motors.
