m30b35 overheating..
  • hammertime
    • Jul 2012
    • 55
    just recently, my e30 started overheating. it takes normal time to running temp, but begins to just keep climbing. Car has had the thermostat removed. I was wanting to try and bleed the lines, but it states that you need to turn your heater on high. I have no heat in my car, therefor I cannot do that .Any advice? I'm new to the game and would love a helping hand.
  • noid
    • 1536
    Does it only keep climbing while idling or also while driving?
    I had overheating problems which I covered here:
    Diagnose and fix BMW E30 cooling system and overheating problems: thermostat, radiator, water pump and head gasket checks in order.
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
      The point of turning on the heater is to get flow through the heater core push out air from the core. If you don't have a heater it can't have air in it.
      The description of the problem sounds like either a clogged radiator or air in the cooling system from a leaking head gasket.
      • hammertime
        • Jul 2012
        • 55
        Originally posted by jlevie
        The point of turning on the heater is to flow through the heater core push out air from the core. If you don't have a heater it can't have air in it.
        The PO also removed the Thermostat. When I start the car, and fill up the expansion tank, there is no flow when I burp the line. Its as if my water pump is bad.
        • hammertime
          • Jul 2012
          • 55
          Hey guys, completely different question, but how do I see what my motor came out of? He said an e24 5 series, but id like to make sure I'm buying parts for the right engine lol
          Sent from my Droid using Tapatalk 2
          • dannyyisntt
            • 3141
            Post up a picture of the engine.
            A simple way to tell is seeing if it says 3.5 on the intake or 3.2/3.5 (3.5 is a b35, 3.2/3.5 is b34)
            Then just buy the appropriate parts for that engine.
            • hammertime
              • Jul 2012
              • 55
              Well its an m30b35, thanks.
              • canakami
                • 743
                Are you sure? Cause if it came out of an E28 5 Series it's an M30B34 or earlier. B35's came in the 88+ E24 6, the E32 7(iirc), and the E34 5 series. I can't speak to the parts difference, but better safe than sorry.
                Always chasin'
                • 1craze30
                  • 1224
                  B35 is from 88+ 5, 6, and 7 series cars. Thermostat is same on b34 and b35 cars. Flush the radiator, and put a thermostat in.
