Driveshaft shimmy: csb or bad ujoints?
  • Balleristic31
    • Aug 2009
    • 4198
    So my new eta has a bit of a shimmy from the mid driveshaft area in 1st and 2nd gear at low rpms.
    Is this most likely to be a bad csb or do I need to replace the shaft due to bad u joints?
    -NICK
  • reelizmpro
    • 9558
    Sounds like csb to me, especially since u said it was coming from the mid shaft area.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
      Inspect the CSB to see if the rubber mount has failed. If so, the cause of that failure is almost always bad u-joints in drive shaft. In which case you replace both.
