Help! Stuck at gas station
  • Fusion
    • Nov 2009
    • 3659
    Sorry for wrong section.
    Car won't start, fuel pump seems ok, voltage to FP only 2-2.6V.
    Relay? If relay which of the 3 is it and which pins should I jump?
    I can't search cuz I'm on slowass edge on my cell.
  • F34R
    sLaughter
    • 12376
    Could be the coil
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • Fusion
      • Nov 2009
      • 3659
      M50 swap
      The pump needs 12V
      Battery is fine, showing 11.6V
      • Thizzelle
        • 4422
        blue one in middle
        "I wanna see da boat movie"
        "I got a tree on my house"
        • Fusion
          • Nov 2009
          • 3659
          FP gets 2.0V even with key off
          • Fusion
            • Nov 2009
            • 3659
            Even jumped getting 2.0V.
            Voltage to and from relay/jumper is ~12V
            • Fusion
              • Nov 2009
              • 3659
              Ok I'm retarded, 11V starting so pump is dead.
              Fuuuuuu Walbro only has 8K miles.
              • travish325
                • Jun 2012
                • 1151
                did you check your ground on the pump?
                • Fusion
                  • Nov 2009
                  • 3659
                  Had to get a friend to tow me.
                  Any idea why a year old Walbro would die? Is there any chance of getting it running again?
                  And is it normal that there's about 1.8V on the pump connector all the time even with the key out?
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    Battery should be at 12+ volts with the engine off, 14 or so with it running. If yours is showing 11.6, it's dead.
                    • Danny
                      • 14216
                      I actually just did my dad's fuel pump yesterday. Check the contacts underneath the connector on top of the fuel pump carrier. His we're old and the wires were no longer making good contact. I soldered on new wires with heat shrink and all is well.
                      • Fusion
                        • Nov 2009
                        • 3659
                        It was 12.2 but after some attempts at starting it etc. it dropped to 11.6. I sat there over an hour.
                        I'll check the contacts. I soldered them myself back when I installed the pump (E30 carrier modified to fit the Walbro), but that could be a weak spot.
                        • b*saint
                          • 3794
                          I agree with checking the ground.
                          Ma che cazzo state dicendo? :|
                          • Fusion
                            • Nov 2009
                            • 3659
                            Thanks guys.
                            Should I be checking the ground from the relay or on the pump connector?
                            I think I read somewhere that even the big groung wire (engine->body) could effect this?
                            • Jaxx_
                              • Dec 2009
                              • 1880
                              just curious, where did you buy your walbro? There are a lot of fakes.
