There is a fog light indicator on the left side of the cluster. It is white, but I think it should light up. It is white like the oil and battery warning that then lights red. I believe this should light green. My car does not have a bulb in this socket. So, I put a known good bulb in and it did not light. I used the bulb for the brake lining light. The fogs work perfect. Is this thing supposed to light?
Is this light supposed to work on my dash?
Tags: None
Yes, should light up green.- Josh
1990 325is
Need a shift boot?
Looking to buy shift boot frames, PM if you have one to sell
Here's what happens when you let the internet pick your license plate -
Hmmm, is there anyway to fix it? It has not had a bulb in it for the last 10 years. Even with a good bulb it did not light.Comment
