My OBC isnt working.
  • IronHeart e30
    • Sep 2012
    • 14
    Hey I new and I really want to fix up my 325e (early) e30. I notice my OBC isnt working and I wanted to know if its a wiring issue or do i just need to buy a new one. Cause the screen doesnt light up n nothing shows for me. what should i do?
    Thanks
  • Nick_S
    • Apr 2011
    • 3658
    Try yelling at it for a bit.
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
    • dnguyen1963
      • Nov 2011
      • 2651
      The lights are probably burnt out. You can either buy a new light bar from Pelican or do a LED conversion. Here is how to do it.
      http://www.iprimus.ca/~trauttf/temp/OBC/OBC-LED.htm
      • Crippled Crip
        • Sep 2011
        • 160
        • dnguyen1963
          • Nov 2011
          • 2651
          You do not need to remove all that stuff to get the OBC out. Here is a simpler way...
          • be34st
            • 1277
            On my very first e30 the obc was doing the same thing. I had had it for about 3 months and one day I was in a bad mood and my friend asked what it was and whats it supposed to do? I got pissed off and punched it, then it turned on and worked ever since.
            no lie, no lie, no liiieeeiiieeeiii!
            07 Designio E63 AMG / 1984 318i (M20Swapped)
            • be34st
              • 1277
              Your sig almost got me fired!
              • ZinnoBerrotEta
                • Dec 2010
                • 240
                Have you tried the checking your fuses? 10, 12, 21, 23, and 27 all could cause problems with the OBC. Start with that first, it could be that easy. Locations 10, 12, 21, and 23 are 7.5 amps and location 27 is a 30 amp fuse. Sometimes the fuses can look visually acceptable and still be bad. My OBC went blank last night and was remedied by simply replacing a fuse in location 23.
                It's good preventative maintenance to replace all of your fuses and it could easily solve some nagging problems.
                Here is a quick link to some cheap OEM fuses.
                http://www.bmaparts.com/ShopByVehicl...@@Fuse&mode=PA
                The fuse box mainly consists of 7.5 amp, 15 amp, and 30 amp fuses, so you only need to buy those three packages.
                If a blown fuse isn't the cause, follow the links that the guys from above posted. Great, indepth DIYs on removal and replacement.
                Also, pick yourself up a Bentley service manual for the BMW E30. It is the absolute best tool for any E30 owner to have.
                Welcome to r3v!
                • IronHeart e30
                  • Sep 2012
                  • 14
                  Thanks for all your help! iTS AMAZING that i all this help form people with e30 like u guys. Thanks. I will look at the fuse ths weekdn when i havea day off.
