Car won't start need it asap HELP
  • London
    • 532
    So today my car ran fine. I parked and jacked it up, took out the cone filter and realized that I had installed the lower radiator hose upside down
    So I went ahead and drained the radiator took the cone out, flipped the hose put it back and installed the factory airbox. Car sat most the day then tonight I went and lowered it off the jacks, put some coolant in and went to run the heater and such to bleed the system. The car turned over, then the revs dropped down and the engine stalled. I tried to start it again and it wouldn't even turn over.
    I let it sit and tried again and it still didn't turn over
    Whats going on here??? I need my car asap for work and school so this is really not good. Help please :(
  • Cletonius
    • 2809
    Did you reconnect the afm?
    - Josh
    1990 325is
    Need a shift boot?
    Looking to buy shift boot frames, PM if you have one to sell
    Here's what happens when you let the internet pick your license plate
    • London
      • 532
      Reconnected everything and triple checked it. I'll get in and check the pins or whatever tomorrow
      • London
        • 532
        Double checked the connections and everything appears fine. I tried starting it this morning and it fired right up, and then the idle just fell and engine stalled.
        • Cletonius
          • 2809
          Does your icv buzz with key on but car not running?
          - Josh
          1990 325is
          Need a shift boot?
          • London
            • 532
            How do you mean? I put the key in and turned it so the power came on but not the car, no buzzing. I turned the car over it reved up and stalled I went and checked it, no buzz. Is that what you meant?
            The car responds when I start it up and give it some gas. But as soon as I stop it seems to stall itself. So to me sounds like ICV or maybe a vacuum leak somewhere?
            • Cletonius
              • 2809
              With the key on and car not running, the icv should make a buzzing. If this isn't happening I would check connections and possibly replace the icv. Check the rest of the intake tract while you're in there too, intake leaks make idling near impossible sometimes.
              - Josh
              1990 325is
              Need a shift boot?
              • London
                • 532
                Ok so i double checked the ICV and it is buzzing like you said. So does that mean there's a leak somewhere? I'm gonna check the hoses but I'm positive I connected them all
                • London
                  • 532
                  Welp, I was feeling around and found a large hole had opened up in the afm rubber elbow thing
                  Well at least its something simple, I'm assuming thats whats causing my problem.
