7000 RMP Cluster plus RMP chip
  • motofaith
    • Dec 2005
    • 8
    I have a 1985 325E that maxes out at 5000RMP. My question is will the 7000 RMP cluster from a 325I snap right in. If i get the RMP chip i am guessing it would make a difference and redline at 7000 but i am not sure. Can someone point me in the right direction and help me get my car to redline higer
    • 34839
    RPM?
    it will work but you will need the coding plug from your cluster. also, there really is no point on having a 7k tach with a motor that maxes out at 5k.
    • golde30
      • 11464
      Originally posted by nando
      RPM?
      its FUH RAZE NIGGA BITCH!!!!!!!!!1111eleven
      IG: @Baye30
      • motofaith
        • Dec 2005
        • 8
        rmp
        wont the rmp chip raise the max from 5000 to 7000?????????????
          • 34839
          RPM?
          no, the chip is not going to raise your RPMs to 7000. the eta motor is just not capable of that. single valve springs, 5 cam journals, small valves, etc. etc. limit what the motor is capable of.
          • Charlie
            kid tested, administrator approved
            • 6686
            Theoretically I'm sure it could.
            For about 15 seconds.
            -Charlie
            Swing wild, brake later, don't apologize.
            '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
            FYYFF
            • arsevader
              • May 2005
              • 1025
              RPM?
              It might make it just before if barfs the valve train through your hood and propels a valve through a piston crown. :)
              James
              • Jordan
                • 12913
                Indeed.
                A stock eta engine (with a unlimited chip) could rev to about 5800 or so absolute max before valve float would cause piston/valve contact.
                Its a economy car man, not a hotrod. Buy a 325iS or something...
                https://mtechniqueabs.com/
                • E30godz
                  • 1524
                  if you've got some mechanical aptitude, make a 2.7i.
                  however i will divulge no details on how to make one.
                  • motofaith
                    • Dec 2005
                    • 8
                    thanks
                    wow i really apriciate all the responses i got from here. Really cleared some things up for me. But just out of curiosity what is the best modification my e30 can handle besides a turbo
                    • permit
                      • Mar 2005
                      • 3363
                      Fog lights.
                      • NC325iC
                        • Mar 2004
                        • 6565
                        hahahaha
                        suspension probly
                        • kowalski
                          • Jan 2005
                          • 1791
                          lots of go fast stickers, and a brushed stainless ebay trim set.
                            • 34839
                            no need for the sarcastic comments guys, he's already confused enough. :P
                            • AndrewBird
                              The Mad Scientist
                              • 11898
                              You could swap an I head onto the E block with a little modification to the head, or put I valve springs and an I cam into your E head, once again, with slight modification. Either way, without a lot more, you aren't going to make much more power.
