rich running low idle e30
  • mannyuk
    • Sep 2012
    • 74
    vacuum hose from fpr to manifold is good
    • Cletonius
      • 2809
      How old is your oxygen sensor? I know you said you passed smog but with what you described and the other usual stuff checking good..... might be time to hookup a scan tool at your buddy's shop and watch real time data; see if you can see the sensor cycling.
      - Josh
      1990 325is
      Need a shift boot?
      Looking to buy shift boot frames, PM if you have one to sell
      Here's what happens when you let the internet pick your license plate
      • mannyuk
        • Sep 2012
        • 74
        so changed over the coolant temp sensor and checked vac line from fpr and still the same.
        how does one clean the air flow meter?
        thanks guys
        • salvageland
          • Aug 2016
          • 149
          Just wondering if you every got the rough idle resolved? My 93 vert is having the same issue. Replaced just about everything. Blue sensor, AFM, O2, rebuilt head, checked all intake joints, cleaned cap and rotor, 150-160 psi across all cylinder, plugs are new but get dark buildup after a few hundred miles. Still has a rough idle, almost seems to be misfiring every 5-10 seconds. Mine unfortunately will not pass smog at at idle and 15mph, but under all emission limits at 25mph! Original Cat on the car.
          Really stumped. :/
