TPS help
  • Erick
    Official R3V Drifter
    • 11169
    TPS help
    Hey guys, my car is acting up and I think it's my TPS because at WOT the engine just dies down, as if I lifted the throttle.
    Anyhow, I'm getting a potentiometer to find out the idle and WOT resistances so I can adjust it. Does anyone know what are the default volts in the WOT and idle setting?
    Thanks,
    Erick
    ..::Support FullOpp::..
    FullOpp Stickers for sale!
    Feedback Thread
  • Erick
    • 11169
    I ran the ECU fault code and I got 1-2-2-2 (Lambda Control 1). Replaced the o2 right now and nothing.
    Feedback Thread
    • Axxe
      • Aug 2004
      • 3355
      Check fuses. I had a similar issue, turned out to be a blown 15A fuse, can't remember the number though.
      Keep it slideways!!
      • permit
        • Mar 2005
        • 3363
        Did you include the coversheet?
        • Erick
          • 11169
          Checking that out right now.
          Feedback Thread
          • Erick
            • 11169
            Nope, that wasnt it...
            Feedback Thread
              • 34844
              I'm pretty sure the TPS is just an on/off switch, it doesn't have a resistance range like a potentiometer or anything. in any case definetly check on it, and also check your injector harness for corrosion (the plug is right under the throttle body). you can also drive with your TPS disconnected to see if the issue goes away (your idle won't be correct, however).
              • Erick
                • 11169
                The issue goes away when the TPS sensor is disconnected. I'm lost now, wtf does this mean?
                My friend and I are reading the Bentley to try to figure this out.
                Feedback Thread
                • T.Dot E30
                  • Mar 2004
                  • 536
                  Replace the sensor.
                  • bimmer8604
                    • 3017
                    Nando is correct, the e30 tps is just an on/off switch. Usually its 5v and like, 1v or something.
                    Just thought id throw that in there.
                    Kyle
                    1988 M3, 97 840, 99 XJ
                    DILLIGAF
                    • Erick
                      • 11169
                      Yeah we figured it out. We got a new TPS in and we got it working properly now, thanks to the potentiometer. The engine keeps getting flooded because it's running so rich tho, and that's problem #2. It's 4:17am and we'll deal with in the afternoon.
                      Feedback Thread
                        • 34844
                        it means your TPS is bad (or the wires are shorting), but you probably figured that out by now. but make sure to check for corrosion in the injector harness like I mentioned, if your throttlebody coolant hoses/gasket are leaking at all they will drip right into the harness, and it can cause the same symptoms as a bad TPS.
                        • asubimmer
                          • 6482
                          did you get the memo? we are putting cover sheets on all our TPS reports now...mmmk?
                          • Erick
                            • 11169
                            We replaced it last night. Havent had a chance to crank it since the engine was flooded. We just put in some new plugs tho so after lunch break we'll fire it up.
                            Feedback Thread
                            • Dominick
                              • Aug 2004
                              • 323
                              i hope you get everything fixed, this is one badass car.
                              www.ThundaCats.com
