steering wheel hub queation
  • asubimmer
    • 6482
    I put a momo wheel and hub on my car and now sometimes there is a little bit of a grinding sound when you turn the wheel. the stock hub/wheel had some kina grease on it. do I need to put anything on the hub to make it stop? Oh and I'm gonna wire up the horn this weekend...finally :)
  • Digitalwave
    is a poseur
    • 6299
    The hub sits on splines, greasing it wouldn't do anything. Did your car have an airbag before?
    RISING EDGE
    • asubimmer
      • 6482
      yep sure did...it only makes the sound some times...
      • Digitalwave
        is a poseur
        • 6299
        Did you remove that white spring loaded pin that sticks out of the steering wheel? It rides on the airbag ring but you need to remove it when you put a non-airbag wheel in.
        RISING EDGE
        • asubimmer
          • 6482
          I am pretty sure I left that out but I need to take it off this week to do the horn so I'll check...I didn't have enough time this weekend to do it.
