help!
  • nugentnsb
    • Jul 2011
    • 444
    help!
    friend jacked the car u wrong and bent this piece under the car, im figuring this is the gas tank? drove it around for a while and smelt gas, the area was leaking a bit. Now the car wont start, any ideas?
  • FLG
    • Sep 2011
    • 3165
    Yeah your friend is an idiot.
    Thats right in the pump area too. If you smell gas and its cracked and leaking, find a good used tank and get to wrenching...hopefully the pump is ok.
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • KillaCam
      • 2103
      Originally posted by flg
      yeah your friend is an idiot.
      +1
      Originally posted by E30_(1st Musk)_
      HONDA IS WHERE EVERY TREND DIES! .
      24v swap Oil Pan..F/S
      • AndrewBird
        The Mad Scientist
        • 11898
        How the car got on it's side.
        • nugentnsb
          • Jul 2011
          • 444
          • poopin04
            • Jul 2010
            • 1396
            Yeah, I'd kick my friend in the balls and not say sorry afterwards.
            Click here to leave me feedback on our transactions. :p
            • nugentnsb
              • Jul 2011
              • 444
              car turns on but wont start, cant hear engine or anything. is it just the gas tank? or fuel pump too?
              • ELVA164
                • 4861
                It depends why the car won't start, but considering the circumstances it sounds like it could be fuel starvation. The pump could be damaged, or the bottom of the tank could have moved/blocked the pickup.
                • dnguyen1963
                  • Nov 2011
                  • 2651
                  It takes five minutes or less to remove the pump and check for damage. Your gas tank is trashed and the pump is sitting right where the danage is.
                  • nugentnsb
                    • Jul 2011
                    • 444
                    just opened it up today, fuel pump was bent, got a new fuel pump but wont fit, cause of that dent. so i guess installing new fuel tank is the next thing to do
                    • dnguyen1963
                      • Nov 2011
                      • 2651
                      Ok, these tanks are steel so you can gently knock out the bent. Use a solid round end wooden stick and a rubber mallet to gently pound it out from inside the car. Take your time and you can make it work. It will not look pretty, but it is under the car. Good luck.
                      • Threehz
                        • 1480
                        Yeah, shouldn't be too hard to push out a dent directly below the fuel pump.
                        GL
                        Different strokes for different folks.
                        • nugentnsb
                          • Jul 2011
                          • 444
                          ill try to unbend it tomrow :D, lets see how this goes.
                          • nugentnsb
                            • Jul 2011
                            • 444
                            ok so i unbent the fuel tank, dropped the new fuel pump in, the engine still just gives a click when i turn the ignition, could this be a bad starter? or relay?
                            • nugentnsb
                              • Jul 2011
                              • 444
                              there is a slight gap between the fuel pump and gas tank, does it have to be completely sealed?
