help!
  • nugentnsb
    • Jul 2011
    • 444
    ok so i replaced the starter and i can hear the engine trying to idle but i think theres a fuel starvation issue, my fuelk pump isnt turning on, is there a relay or fuse i should replace?
      There is only the fuel pump relay and fuse 11 in the circuit to the pump.
      • nugentnsb
        • Jul 2011
        • 444
        ok i jumpered the pins 30 and 87 from the fuel pump relays, and its turning on, i try starting the car, but it just revs without me pushing on the gas. what does this mean? it wont idle
        engine is just accelerating wiuthout me pushing on the gas pedal
          That is most likely the result of intake leaks. Have a shop run a smoke test and repair as indicated.
          • nugentnsb
            • Jul 2011
            • 444
            nvm throttle cable was stuck, drove the car around and then it died again. headlight started dieing, is this a sign of a bad alternator? tried to start the car but it wont start again. fuel pump not turning on anymore
