clunking - differential?
  • jrobie79
    • Mar 2006
    • 2525
    TL;DR - clunking noise, doesnt appear to be suspension, or any loose driveline bits (guibo, diff input/output flanges)
    I have this weird clunk whenever I step on the gas coming from the rear. At first I thought it may have been my trailing arms as I have the weld on kit, so maybe they were getting loose...this doesnt appear to to be the case.
    Whenever I shift from reverse to 1st I hear a clunk coming from the rear of my car. As I'm driving if I let off the gas peddle and coast for any distance and go back to step on the gas I hear the clunk. This makes me believe its in the drive line - loose giubo bolts, loose d/s to diff bolts, or loose axles, however it appears everything is tight. If I'm going downhill and put it in neutral and step on the breaks, nothing (which is why I'm suspecting the diff). My dad said something about it being inside the diff...worn gear or something that is causing some slop.
    ps. I jacked my car up and drove it from 1st to 3rd up to about 40 mph and there was no noise, during shifts, letting off the gas and re-accelerating, or shifting into reverse/1st.
    any help as its getting annoying and I don't want something catastrophic to happen. I'm going to swap my sisters open 4.10 in over the weekend and see if that helps. If it does turn out to be the diff, what is wrong with it and how can I fix it aside from buying a new diff. (fluid is full and less than 1 year old - motul synthetic)
    if this is more appropriate in the driveline thread please move, couldn't nail it down the cause so I didn't post there
    1991 318i ---- 308K - retired
  • VinniE30
    • 2113
    I had this problem and it ended up being the rear subframe bushings.
    Zinno '89 <24v swap in progress>
    • jeffnhiscars
      • Jun 2011
      • 6010
      I had very similar symptoms and it turned out to be my trans mounts had turned to mush. I know you said "rear end" but noises travel and a bouncing trans can cause contact elsewhere. GL
      Alice the Time Capsule
      • jrobie79
        • Mar 2006
        • 2525
        The tranny mounts are less than a year old..the subframe bushings are IE poly, also less than 1 year old. I'll take a look either way. Hopefully its the tranny mounts if anything - subrame is a bear.
        • Quadrajet
          • Jul 2008
          • 1278
          If you still suspect the Diff. when you have the car up, put the trans in Neutral and have the parking brake set. Or have the rear tires on ramps, then grasp the differential flange and twist to see if you have too much lash in the ring and pinion. If you remove the shields you can see if your universal joints are done too, while your there.
          • SkiFree
            • Jun 2011
            • 2766
            One more thing to check for would be the rear U-joint of the driveshaft. With the car in the air give the rear section of the driveshaft a good wiggle and see if there is any play in the joint.
            EDIT: shoot, Quadrajet beat me to the punch.
            ADAMS Autosport
            • davem
              • Jun 2010
              • 705
              drive train lash, your dad is right.
              • jrobie79
                • Mar 2006
                • 2525
                if it ends up being this, how is it fixed w/o buying a whole new diff? I'm hopefully swapping over the winter, so I guess I only need this to last till I put it away (first snow)
                • davem
                  • Jun 2010
                  • 705
                  just drive it nothing catastrophic will happen. this is just what happens with a manual car with this kind of drive train and lots of miles of wear.
                  • jrobie79
                    • Mar 2006
                    • 2525
                    I'm taking a trip to Miami the first week of December, I dont need my diff to explode on me in north carolina
                    • Vivek
                      attention whore/retard/bitch
                      • 6167
                      Check the locking nut on the drive shaft. It's a pain to get to, but that's what was wrong with my dad's car. Does yours clunk when you start off, ie as soon as the clutch hits the friction point and loads the driveline?
                      1992 Mauritiusblau Vert
                      2011 Alpinweiss 335is coupe
                      2002 540i/6 Black/Black
                      2003 GSX-R 750 (RIP)
                      • Andy.B
                        • Sep 2011
                        • 1650
                        I had this problem, and after replacing bushing after bushing, found that rust had built up around the diff to subframe bolts around the bolt heads, causing the diff to be loose enough to clunk. Due to corrosion, the bolts felt tight. I had to use some heat to work them free, then re torque them down. Problem gone. Just something to check.
                        Sent from my Galaxy Nexus
                        • Holland
                          • Nov 2008
                          • 7178
                          This hasn't been mentioned, but check the shape of your axles as well. When run dry they will make a clunking sound when initially moving forward.
                          Originally posted by DEV0 E30
                          • eurotrash
                            • May 2007
                            • 768
                            Also double check your subframe mounts. Poly is meant to be changed reasonably frequantly. Not a big deal on a race car as they dont see much driving aside from tracktime but dailying poly can lead to much quicker deteriation of the mount as they dont flex with movement like the rubber mounts would. Naturely your subframe being harder then the poly this leads to them breaking down quick.
                            • NLM Hollywood
                              • Sep 2012
                              • 16
                              I've got this exact same problem and have yet to identify the issue. I do know that on one of the four E30's we built into race cars we had this issue and it was identified as slightly loose bolts from the driveshaft to diff. Since I'm not the one who found or fixed it, I'm not 100% certain, but it's something to check.
