windshield wiper motor replacement
  • timninja
    • Feb 2011
    • 302
    I cant figure this puzzle out,ive got the main heater core panel out,ive got the motor loose,I cant get the outputs below the valance to pull the damn motor out,i hope this makes sense !
    Thanks allot,tim
  • timninja
    • Feb 2011
    • 302
    By motor I mean linkage +motor btw
    • agile30
      • 832
      What do you mean by outputs? The part that grabs the linkage?
      Originally posted by Good & Tight
      It takes real man to mount a big woman, all you haters are just scared boys.
      • timninja
        • Feb 2011
        • 302
        Where the wiper arms mount,spindles might be the right word
        • timninja
          • Feb 2011
          • 302
          The peices that mount with the 13mm and c-clips
          • agile30
            • 832
            Is the linkage bad? Why not just remove the motor. That's the easiest thing to do.
            • timninja
              • Feb 2011
              • 302
              I cant get to the last 10mm bolt,because the smaller arm won't cycle out of its way
              • timninja
                • Feb 2011
                • 302
                Well actually all the joint bushings are bad too.
                • Todd Black 88
                  • Oct 2007
                  • 3449
                  You need to remove the blower motor cover, the blower motor, and then the remaining blower motor housing if you want to pull the entire linkage.
                  Originally posted by codyep3
                  I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                  2001 silver/Blk 325 cabby. SOLD
                  2002 325xit Sil/blk. SOLD
                  2010 F650gs twin
                    • 34839
                    you have to pull the cover off. the motor actually comes out pretty easy.
                    the linkage comes out easy too if you remove the intake manifold.
                    • timninja
                      • Feb 2011
                      • 302
                      The motor pops out after I remove the 4 10mm bolts right?
                        • 34839
                        yeah I think 3 bolts to the wiper frame and 1 bolt to the linkage arm.
                        • glucklich21
                          • 1912
                          The worse job on an E30 I think and that's after the crap I've done with the cabrio.
                          • Quadrajet
                            • Jul 2008
                            • 1278
                            timninja, if your linkage is all bad, I just finished gaining access to that on a car I'm parting out. Let me know if you need it.
                              • 34839
                              It was really easy with the intake manifold out of the way. taking out the heater box to get to it was much more time consuming than actually getting the linkage in and out.
