tach comes on late
  • 2002jm
    • Sep 2005
    • 2073
    tach comes on late
    On my 88ix the tach does not work when the car turns on...? However, about 2-3 minutes after the car starts and I am driving down the road, it comes to life and works fine.
    Is this a lose wire, short, or the tach is dying???
    jm
  • Ceeker
    • Sep 2009
    • 2821
    jm
    possible loose contact between the tach pins going into the circuit board or a loose cold solder connection. I have the same problem. in cold weather it doesn't want to work until the car heats up and then I slam my fist down on the dash and it works..lol. also something else to check are the NIcad batteries; they could be on the way out if this wasn't happening before.
    • Gregs///M
      • Mar 2012
      • 2459
      Replace SI board batteries if they have not been replaced before.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • hahaitzskippy
        • Oct 2012
        • 116
        Check the ground yet? I did that and everything has been working fine since.
        2007 Mazda CX-7 (red TURBO!!)
        1985 BMW 318i.... beige!
        2007 Suzuki GSX-R 600 (red)
        previous cars
        1) 1994 Isuzu Trooper (blue)
        2) 2005 Scion tC (panda w/ CF)
        3) 2001 Toyota Avalon (silver)
        4) 1988 Nissan Pulsar XE (T top in red)
          This can be a case of a sticking needle in the tachometer. Start the engine, then tap on the cluster and see if the tach comes alive.
          • Mr. Tasty
            • Jul 2011
            • 3421
            this happens to me in the summer. I painted my needles with finger nail paint, and when it gets hot enough, it sticks to the stopper. Gentle tap gives it way.
            2014 Alpine White 335i MSport
            (Daily Driver)
            Full Mperformance Aero
            KW V2 Coilovers
            VRSF Catless Downpipes
            • FLG
              • Sep 2011
              • 3165
              Same here.
              Sent from my Galaxy Nexus using Tapatalk 2
              -Build http://www.r3vlimited.com/board/showthread.php?t=295277
              • 2002jm
                • Sep 2005
                • 2073
                thanks for the input
                I am going to take the cluster out and check the grounds and to see if the wires are in all the way. Mine does seem to come on when the engine warms up, so that is good to know, others are having the same problem.
                thanks again,
                john
                • frankie591
                  • Feb 2012
                  • 545
                  Part of owning an e30 is knowing exactly where and how hard to thump the dash to make the tach work.
                  • dnguyen1963
                    • Nov 2011
                    • 2651
                    Not quite...taking care of your SI board and ground nuts should solve this problem.
                    • 2002jm
                      • Sep 2005
                      • 2073
                      Yes, I was hitting the tach to see if I could get it to move:). No luck, but after 5mins of driving, it turns on and works fine. I think it is a ground problem. PO had it out, might not have tightened everything down.
                      Will pull it soon and get it done!
                      thanks,
                      jm
                      • Todd Black 88
                        • Oct 2007
                        • 3449
                        My 92 does the same thing.
                        It just sits there until the car is a bit warmer, then it comes to life but sticks at 1500 or so until I rev up past around 4k. After the car is fully warmed up, it's fine and smooth.
                        Lmk what you find as I am interested.
                        I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                        2001 silver/Blk 325 cabby. SOLD
                        2002 325xit Sil/blk. SOLD
                        2010 F650gs twin
