Wiper issues. When wipers wipe, it hold at the top for 2secs...
  • audiquattrot
    • May 2008
    • 3836
    then comes down. It isn't as fluid either. It skips a bit as its' coming up. Motor shot?
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
    • 34844
    sounds like it. you can actually fix the motor, it's just that the grease inside gets hard and full of gunk so the contacts don't work quite as well. but it's easier to just replace it.
    • audiquattrot
      • May 2008
      • 3836
      cool thanks! was hoping it was something as easy as a relay somewhere....guess I'm not that lucky!
      judging by one of the writeups this looks like a PITA to replace...ugh...i hate winter wrenching
      #snwmble
      Current:
      Past:
        • 34844
        it's really not that bad. figure maybe an hour. use a ratcheting 10mm wrench since you can't see and it's tight. it's just 1 plug and a few bolts. the trick is to remove the plastic cover before trying to take out the motor. It will deform when you pull it out but that's OK. zip tie the cover back to the motor when you're done.
        Just recently I replaced the entire wiper linkage, blower motor, etc. I'd already done the wiper motor. Out of those three jobs the blower motor was the biggest pain. the wiper linkage was much easier than everyone made it out to be. I spent 5 minutes on the linkage and about 2 hours on the blower motor (partially because I had to repair one of the flapper doors).
        • audiquattrot
          • May 2008
          • 3836
          thanks for the tips! i found the blower motor pretty simple to replace, but its' always the easy jobs that end up being a PITA! btw do recommend a place to order a new/remanufactured one? or should i just source a used one. I'm gonna look up part #s/pricing etc now....
          #snwmble
          Current:
          Past:
          • audiquattrot
            • May 2008
            • 3836
            pricing doesn't look bad...i'll order a new one
            #snwmble
            Current:
            Past:
              • 34844
              yeah, it's not worth doing used, any 20+ year old motor is going to end up being worn. basically after 20+ years in the PNW, my entire wiper system was pretty well shot thanks to 8 months of rain a year.
              • audiquattrot
                • May 2008
                • 3836
                yup! i was expecting a $600+ part. @ a lil over $100, its def worth to buy new. Just ordered it =)
                #snwmble
                Current:
                Past:
                • audiquattrot
                  • May 2008
                  • 3836
                  odd thing is it works fine now, but i'll put in the new motor for piece of mind.
                  #snwmble
                  Current:
                  Past:
                  • dnguyen1963
                    • Nov 2011
                    • 2651
                    I used to have problem with my wiper then found out how hot the wiper replay could get. I took the relay cover off and drilled a bunch of small holes in it for vent. It has been working fine ever since.
                    • audiquattrot
                      • May 2008
                      • 3836
                      that might be why mine started to act up the other day. It acted up shortly after a torrential downpour, so i clicked the wipers to full speed. When i kicked it down to slow, thats when it started to pause when it would go up. Wonder if changing the motor will make any difference if that's the case. At the moment it seems to be working fine.....but have the new motor ready.
                      #snwmble
                      Current:
                      Past:
                        • 34844
                        there are 2 million E30s that have a wiper relay without holes drilled into it. sounds like your relay is going bad.
                        • dnguyen1963
                          • Nov 2011
                          • 2651
                          On my list to replace, but it has not acted up in nearly a year since I drilled those holes.
