windows/blower/ sunroof/ mirrors...ect dont work!
  • KillaCam
    • 2103
    i have searched and found that it is the unloader relay/starter
    where the fack is the unloader relay
    i replaced all the relays in the fues box except the wiper one and that didnt fix it.
    is there a relay under the dash or in the glove?
    oh and the reason they arent working is because i think i shorted something out when i was hooking up my e36 switches
    Originally posted by E30_(1st Musk)_
    HONDA IS WHERE EVERY TREND DIES! .
    24v swap Oil Pan..F/S
  • dnguyen1963
    • Nov 2011
    • 2651
    Here it is...
    1999 BMW E30 Fuse Box Diagram 1999 BMW E30 Fuse Box Map Fuse Panel Layout Diagram Parts: wiper control unit, low beam relay, normal speed relay, horn relay, high beam relay, low beam relay, unloader relay, high speed relay, inloader relay, fog light relay.
    • KillaCam
      • 2103
      Originally posted by dnguyen1963
      doesnt help, i replaced all of those fuses already and nothing is working still
      • bernzpeed
        • 3917
        wow there is a 1999 e30?
        89 E30 S52
        Transaction Feedback.
        • dnguyen1963
          • Nov 2011
          • 2651
          It's a typo from OP...1989.
          • dnguyen1963
            • Nov 2011
            • 2651
            BMW electronic gremlins are difficult to locate, especially with that many non-working components. Elimination process is probably the only way to go...isolate working component one by one until you find one that does not work. Good luck.
              The unloader relays are K5 & K7 in the fuse box. On an 88 or later E30 those are controlled by the unloader switch in the starter solenoid. Since the relays have been replaced, the next place to look is to the starter.
              • KillaCam
                • 2103
                ya i got them to work after i replaced all the relays and stuff.
                does the window circuitbreaker thing, that one on the HVAC/center console act like a home circuit breaker, where if to much power is going through it it clicks itself. (kinda like a reusable fues)
