E30 speedometer and odometer
  • whaaac
    • Oct 2012
    • 365
    for the e30 gurus
    since the common problem for e30s is that the speedometer and odometer.
    how do you know for sure it doesn't work?
    for my 84 325e, the speedometer and odometer work once in a long while but its usually just dead.
    do you think its the wires that's not connected correctly or is this the problem of the e30s?
    help!
    thanks guys!
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5604
    When your driving and the miles don't change. That's how you know. :drink:
    • slammin.e28
      שמע ישראל
      • 12054
      Speedometer would be the SI board, correct guys? Unless the sender at the rear diff is going?
      Odometer would be the gears, but usually they just stop and are done.
      • whaaac
        • Oct 2012
        • 365
        people have been telling me that its the plug that is connected to the differential.
        thing is that sometimes (rarely) whenever I drive over a bump or something the odometer and speedometer works for like less than a mile or two.
        • Nick_S
          • Apr 2011
          • 3658
          Sounds like a bad connection. Part it out.
          91 318is M50 swapped
          05 Honda Pilot
          24V swap thread
          • whaaac
            • Oct 2012
            • 365
            where do you think i should start?
            • Nick_S
              • Apr 2011
              • 3658
              Sorry that was meant to be a joke, like part the whole car out. I suck at the internet.
              But on a serious note. I had a neon that did the same thing. Hit a bump and the whole cluster would go down. Had a bad connection at the harness on the back. Pulled it out, cleaned it real well and made sure it was secure and it went away.
              05 Honda Pilot
              24V swap thread
              • Gasturbine
                • Sep 2012
                • 261
                Usually cold solder joints in the cluster. Pretty easy fix if you know how to solder.
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  I have new gears in all 4 of my e30's but one of them still has an intermitent speedo. A smack to the cluster gets it going so its surely a bad connection or solder joint.
                  Alice the Time Capsule
