Engine hood isolation
  • John Beton
    • May 2012
    • 8
    Hello guys,
    not the most important question, I know, but is it harmless to run without the isolation beneath the engine hood?
    I know people that say it is bad because the heath will eventually cause problems with the paint on the top of the hood. But i often see people running without the isolation like lots of guys here on the forum.
    Now, is it harmfull or not?
    My isolation looks bad and needs replacement, but on the other hand i would rather use the money for something else on the car. I have looked around for a similar material so i could make it on my own, but haven't found it yet ecxept for very big amounts.
    And will teh engine noise increase aswell?
    Thanks mates!
    • 34844
    it's for noise. it won't affect anything without it.
    haven't had it on my hood for nearly 6 years.
    • Exodus_2pt0
      • 5943
      I take it off of every single car I have ever had. No paint problems, that's what wax is for. ;)
      No E30 Club
      • fronton
        • Oct 2009
        • 1262
        I don't know anything about hood isolation but it sounds more like you are curious about insulation. It is sound deadening, you can run without it and have not other drawback. Engine noise will not increase but you will hear more of it.
        • John Beton
          • May 2012
          • 8
          Thanks guys, I will remove it. Will I notice any change in terms of time to get the engine heated up or is it 100% only for insulation purpose?
          • ELVA164
            • 4861
            Warming the engine up won't take longer than usual, and if it does it won't be enough to make any real difference. The material really doesn't insulate for temperature as others have said, just sound.
            • RAYREY
              • 212
              i have been debating on taking mine off....insulation is messing up my shiny strut bar!!! LOL Thanks guys!
              1991 325i coupe
              1992 318i conv
              2002 540i sedan
              What did the e30 owner say to the other e30 owner? LOOKING GOOD!
