Leaking red fluid. What could it be?
  • IS300E30
    • Apr 2009
    • 408
    I checked the automatic transmission fluid and the power steering fluid and both seem like it is at the correct level.
    Whatelse leaks red besides the auto transmission fluid and the power steering fluid?
    Also, it seems like it is leaking on the middle section of the car if that helps.
  • ttrousdell
    • Nov 2009
    • 1770
    a red fluid coming from the the middle of the car is tranny fluid if I was to guess. Id keep an eye on that dipstick.
    The Build:
    • willworkfore30s
      • Aug 2011
      • 1090
      Could be old shitty gas if your car has sat for a while, but most likely tranny fluid
      • Vivek
        attention whore/retard/bitch
        • 6167
        Most likely tranny. Does it smell like ATF?
        1992 Mauritiusblau Vert
        2011 Alpinweiss 335is coupe
        2002 540i/6 Black/Black
        2003 GSX-R 750 (RIP)
        • TobyB
          • 5296
          b l o o d ....
          t
          • AndrewBird
            The Mad Scientist
            • 11898
            Some brake fluid is red. Check your hardlines that run under the car.
