R3V I need your Help
  • MonkeyMadness
    • 3251
    What is the small plug in the picture for or to?
    This is a 91 318is M42 harness.
    Its a small 2 wire plug in the glove box with the DME that goes up under the dash.
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5604
    Is that the plug for the flashlight? The rechargeable one?
    • smerfs
      • 319
      Fairly sure it is - when I plugged my flashlight in the socket looked identical
      320I - under construction
      • MonkeyMadness
        • 3251
        Wat? o_O
        No this plug was plugged in to some wire that snake up undet the dash.
        It wasn't just a dead plug hanging there.
        I just need to know whats on the other end of the two wires that snake up under thw dash.
          I don't think so. I'd have to check the ETM, but I think that is how the A/C idle speed and road speed signals reach the DME.
          • ELVA164
            • 4861
            I was swapping ECU's around a couple days ago, and I noticed that there was a black plastic unit like that next to the ECU in the '88 vert and '91 sedan, but not in my '87 sedan. I was actually going to ask what it was, but....here we are. I could take pics tomorrow if it helps.
            • F34R
              sLaughter
              • 12376
              I cannot see the colors of the wires, what are they?
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • MonkeyMadness
                • 3251
                Black w/ white strip
                Light purple w/ white strip
                • samiam3356
                  • Jul 2009
                  • 1901
                  bingo
                  The 24v swap guys that actually managed to keep their AC know this plug well when it comes to trying to keep a smooth idle when you turn the AC on
                  Originally posted by Roysneon
                  $5 shipped?
                  Originally posted by MarkD
                  You are a strange dude, I'n not answering any more posts from you.
                  • MonkeyMadness
                    • 3251
                    Originally posted by samiam3356
                    bingo
                    Awesome thank you guys.
                    I'm in the middle of an M42 swap to 2002 and this plug had ne scratching my head...
                    Thank for all the feed back.. :up:
                    • Sindako
                      • Nov 2012
                      • 116
                      WTF !!! , Guys This Plug Is For The ECU RPM Control for The AC Compressor .
                      It Comes With a AC Cold/Warm Kit .
                      I Have This Plugged In My Car . and If you Remove it The RPM Will Go Really high When you Turn On The Cold AC .
                      • samiam3356
                        • Jul 2009
                        • 1901
                        You are a little late, turbo
                        $5 shipped?
