Oh.. BOB SAGET!
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    Oh.. BOB SAGET!
    I spent all day working on my front suspension and we get stuck at the control arm bushings and sway bar links.
    With the old control arm bushings I can't figure out how to get the old bastards out of the arms.
    With the sway bar links when I turn the but that hold it to the sway bar the fucker just spins and spins.
  • Jordan
    • 12916
    the swaybar link has a flatspot on the other side, i think its 15mm? use it to hold it from spinning....
    BMW special tool for the CA's
    https://mtechniqueabs.com/
    • RobertK
      • Jun 2005
      • 5864
      What do you do when the bushing has rotted out and left nothing but the damn metal pressed in.
      • Skafrog
        • 1732
        get a two jaw puller and use that.
        NASA MidSouth TT Director / GTS2 #018
        Mods: Coastal PS Fluid, 10w40 Oil
        Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
        • RobertK
          • Jun 2005
          • 5864
          Does that shit actually work?
          • Alecs MacDonald
            • 729
            Take your new cabs and lolypops to a machine shop and have them press them in. 10 bucks is well worth the avoided aggrivation.
            '88 325ic
            • Justin B
              Sikky Nar Nar
              • Mar 2005
              • 4273
              You could (also) use a hacksaw and slowly cut through the metal as to avoid cutting into the surface on the bracket, then when it gets really really thin, since its a little wider than the bracket take a small hammer or a punch and a hammer to tap one of the sides, hopefully breaking the bridge and it'll slide/fall out. If you cut all the way through it it also might just grab the hacksaw blade a little firmer, and when its removed it'll break on its own. Basically just taking away some material so it can get smaller in diameter and come out :/
              • Bitburger
                • Jan 2004
                • 147
                i've used this method in the past. Works great.
                  • 34844
                  you could do that, but the new bushings have to be pressed in anyway (unless he's using urethane or something) so he may as well just take it to a shop. they won't charge you much, either.
                  • RobertK
                    • Jun 2005
                    • 5864
                    Actually I do plan on installing a set of Powerflex Poly Urethane CABs
                    • kowalski
                      • Jan 2005
                      • 1791
                      you could use a punch, or a hack saw, or a piece of pipe and press it out, and use a torch with some of those methods.
                        • 34844
                        well in that case hack away.. it's not too hard. I cut out the bushings on a spare set that I had, hoping I would be able to figure out a way to press a new set of M3 offsets in, but I ended up having to get them pressed in anyway.
                        • hamann318is
                          • 3382
                          I had to cut the old CABs out of the brackets, and I was able to press one of the new ones in using a table vice. I still had to take the CABs to get the one I pressed in pressed fully in and to get the other CAB pressed.
                          Take them to a NAPA Machine Shop or something, it was only 15$.
                          The BMW 318 is back. With a vengeance.
                          • 808BMW
                            • 2910
                            A dremel will pwn that little metal sleeve.
                            • RobertK
                              • Jun 2005
                              • 5864
                              Used the hacksaw trick and it worked like a charm. Afterwards I used a flat piece of metal and a vice to press the new ones half way in and then a wood block and a hammer to get it in there the rest of the way.
