fuel gauge is being strange
  • coolflow
    • Aug 2012
    • 81
    my fuel gauge often rises up and then down again randomly.
    When it's running on empty it will go below the red zone to the white stripe BUT when i try and fill it to a full tank there's still 10 litres in the damn tank!
    any solutions?
  • Vivek
    attention whore/retard/bitch
    • 6167
    Tighten the nut on the back of it
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • mcaden
      • Jun 2011
      • 164
      What Vivek said... and also clean up the grounding nut/washer before you tighten it. If that doesn't work, next do a search about your fuel sender/sensor (and difference between late model/early models). And if you have to tap your instrument cluster to get your fuel gauge to work, then read a thread about restoring a solder flow to a joint in your cluster.
      Simply tightening the grounding nut is the easiest and most common solution.
      Good luck.
      Marc
