Weird power steering grinding noise
  • e30Villain
    • Jun 2012
    • 540
    So my car has developed a weird grinding noise similar to this video:
    Everytime i turn it makes that grinding noise. It happens when i start the car but after i drive it a bit it stops. Sometimes it doesnt even do it at all. A few people said it was air in the lines? Any suggestions?
    87 ETA | Hibernating
  • Cronopoulos
    • Jul 2011
    • 2187
    That video sounds more like a whine, pump related for sure.
    Project log -- DIRTY 30
    2.7i * Megasquirt tuned * E85 powered
    • dnguyen1963
      • Nov 2011
      • 2649
      You can always delete your PS if you don't want to fix the noise.
      • e30Villain
        • Jun 2012
        • 540
        I'd rather keep it as a last resort.
        Hopefully it's pump and not rack
        • blocke
          • 1305
          Mine did that. Belt was too tight, stressing the pump bearings. Belt tension correct?
          Parts Wanted
          The Never-ending Resto Mod
          • e30Villain
            • Jun 2012
            • 540
            haven't touched the belt so it would be weird if that was the cause, hopefully it is though. Fingers crossed going to attempt this.
            • e30Villain
              • Jun 2012
              • 540
              Bump still does it. Going to change reservoir, return hose, and pressure hose soon.
              • AndrewBird
                The Mad Scientist
                • 11898
                I'm assuming you've checked the power steering fluid level?
                • e30Villain
                  • Jun 2012
                  • 540
                  Yeah topped it off today ( dexron atf fluid) It did it again after driving like 5 minutes it again went away
                  • e30Villain
                    • Jun 2012
                    • 540
                    would a leak from the resevoir to the pump be the cause?
                    • e30Villain
                      • Jun 2012
                      • 540
                      Sorry for the late update. I changed my Low pressure return hose and the hose that goes from resevoir to pump ( both were leaking). Its been 2 weeks and there is still no noise. :up:
