I've probably put about 50 miles on my e30 the past week. Prior I did not really drive it that much. Well I drove it home from work and then a couple of hours later I started it up to go somewhere and it started as it should. Literally about 5 seconds later the car died and refused to start after a couple of cranking attemps. A day later I hopped in and tried to fire it up and all it would do is turn over and not start. So two days later I was replacing the tail light bulb. The first thing I tried to do was start it and there was no luck. So I replaced my tail light and all and turned my headlights on and what not just to check my other lights. Then I decided to see if it would start about 20 minutes after the intial attempt, so I turned the key and it fired up on the first try and stayed alive like it normally should. I drove it around the block and there wasn't any problems that I could tell.
Any idea what caused it not to start?
I'm afraid to drive it now because I don't want it not to start like it did away from home
