Keeping the e30 the same width.
    12,722 post, rather old member, not new to bmw, thanks.
    ok my eighth e30 its an 1986 325e not even fully bought yet. this is a project and will be built taking my time & sourcing parts.
    so that said, i want to keep the car the same not just with e30 fenders or arches, keep the car at 65.4" ish ( the width of the OG E30 ) a stock coup is 65.4", that's stock & stock on either side of the trans tunnel, ( i have read not to cut into the tunnel, i will research this further ) that is cut out material most unlikely from a donar...
    had a question about suspension geometry, for folks who could be helpfull in this area an i going to through off the current geometry, can camber caster adjustment help, engine is TBD.
    thanks again,
    I see what you did there
    IX being restored here
    Ix turbo build here
      Too much work, I suggest you lengthen the e30.
        If you want a car the same size as an e30 the keep your e30.
        -Andy
          At first I was so confused that it made me hate you, then I saw the other thread..
          :giggle:
          1991 318is - Sold
          1986 325 - Sold
          Instagram - Lamoursum
            cut into the tunnel.
            don't bother with research.
            -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
              i like where this is going
                :rofl:
                Cammed B25 Swap Daily Driver
                Updated 10/1
                  What you need to do is remove trans tunnel, and install jet engine. Then zip tie both halves of your car to new and improved powerplant. This will allow you to narrow your car enough so you don't need 2 seats, you can just sit on the rocket, and the zip ties will allow enough flex so you don't need suspension. In which case I recommend welding steel rods where your struts/springs go
                  85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
                    best bet is to take an e34 and narrow it
                    1989 cirrisblau-metallic 325i
                      This^
                      Oh, and git yer teeth fixed...
                      Suspension tips here...
                      http://www.r3vlimited.com/board/album.php?albumid=757
                        The only way to keep the E30 stock width is to get an E21...
                        Don't ask me how I know
                          Penis
                          Originally posted by codyep3
                          I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                          2001 silver/Blk 325 cabby. SOLD
                          2002 325xit Sil/blk. SOLD
                          2010 F650gs twin
                            get even with semen?
                            Originally posted by BillBrasky
                            That's like Vlad challenging Chip Foose to a car painting contest.
                            Originally posted by acolella76
                            i'm pretty sure 'Phillis' is short for syphilis
                            2007 CVPI, stock and slow
                            1994 tercel, 5efhe swap, i/h/e
                            1984 t-type, 5.3/th350 swap in progress
                            My newest addition:
                            Rebecca Arlene, born 4/19/2013
                              nah, take an e31 and narrow it
                              2014 Alpine White 335i MSport
                              (Daily Driver)
                              Full Mperformance Aero
                              KW V2 Coilovers
                              VRSF Catless Downpipes
