Skinny-ing AND Widening the E30
  • mulletman
    • May 2012
    • 801
    139th post, rather new member, not new to bmw, thanks.
    ok my first e30 its an 1990 325is, not even fully bought yet. this is a project and will be built taking my time & sourcing parts.
    so that said, i want to skinny-ify the front of the car, not just with e21 fenders or arches, shrink the front to 56" ish ( the width of the OG Mini Cooper ) a stock coup is 65.4", that's 9.4" under stock & 4.7" on either side of the trans tunnel, ( i have read not to cut into the tunnel, i will research this further ) that is cut out material most unlikely from a donar...
    then i want to widen the rear of the car, not just with M fenders or arches, widen the rear to 73" ( the width of the e31 ) a stock coup is 65.4", that's 7.6" over stock & 3.8" on either side of the diff mount, ( i have read not to cut into the tunnel, i will research this further ) that is welded in material most likely from a donar...
    had a question about suspension geometry, for folks who could be helpfull in this area an i going to through off the current geometry, can camber caster adjustment help, engine is TBD.
    thanks again,
  • AbsorbantNut
    Non faccio funzionare questa merda
    • Jun 2010
    • 2491
    '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
    • thebutcher37
      • 2877
      I am following both threads.
      Transaction Feedback
      • sarcasmkillsme
        • Oct 2007
        • 255
        Possibly one of the worst ideas I've heard in awhile.
        • LJ851
          • 7919
          Put the pipe down , mulletman.
          Lorin
          The M30 is God's engine.
          • mulletman
            • May 2012
            • 801
            You can't make me.
            • bmw325csi
              • May 2007
              • 4045
              Killed it
              harry/harout
              • decay
                • 5637
                so you basically want to make an e30 deltawing?
                past:
                1989 325is (learner shitbox)
                1986 325e (turbo dorito)
                1991 318ic (5-lug ITB)
                1985 323i baur
                current:
                • AZRRC
                  • Sep 2012
                  • 260
                  THIS
                  best idea ever
                  89 325i Offroad
                  89 325i
                  05 C240 Wagon
                  • deutschman
                    • May 2008
                    • 5958
                    This guy can not be for real. Who's fucking with us?
                    • Kevinl
                      • Oct 2012
                      • 897
                      What would be even cooler is narrow the passenger side & widen the drivers side
                      1989 BMW 325is Lachsilber metallic 5 speed
                      2007 BMW 335i KARMESINROT 6 Speed manual
                      2011 BMW X5 35I
                      • mulletman
                        • May 2012
                        • 801
                        Damn! Why didn't I think of that?!
                        • Eddie Lives On
                          • May 2011
                          • 208
                          McLaren F1 style Gordon Murray would be so freakin' proud
                          • TobyB
                            • 5280
                            It's pronounced Bott- Hell.
                            t
