What is this Tube?
  • ClayW
    • Apr 2011
    • 377
    What is this Tube?
    What is this tube? I opened up the panel to look for the source of my gassy smell (only in cold weather upon starting....weird). Anyway, I found this pair of plastic tubes with fuel line coupling them. The larger of the two seemed to have some fuel on the underside, so I replaced it with a new section of fuel hose and two new hose clamps. But what is it?
    1987 325e Commuter Project Blog
    1967 1600 Project Blog: www.TX02.blogspot.com
  • Stanley Rockafella
    • Aug 2011
    • 4061
    gasoline
    • agile30
      • 832
      gasolina
      Originally posted by Good & Tight
      It takes real man to mount a big woman, all you haters are just scared boys.
      • quikveedb2
        • Sep 2007
        • 2258
        Petrol
        You know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.
        • Cinnabar325is
          • 1064
          Both plastic pipes are part of the fuel expansion system. They go from where you see them through the metal conduit under the rear seat into the RR wheel well and up to the expansion tank.
          '89 BMW 325is Zinnoberrot / '88 VW Jetta GLI 16v Tornado Red / '89 VW Jetta GLI 16v Tornado Red / '89 VW GTI 16v Bright Blue Metallic / '91 BMW 325i Black / '91 BMW 325i Sport Black / '92 VW GTI 16v Black / '92 VW GTI 16v Montana Green / '01 Audi A4 Avant TQM Silver Metallic / '01 VW Jetta GLX VR6 Black
          • ClayW
            • Apr 2011
            • 377
            Would that explain why I get gas fumes in the cabin when it's really cold?
            • ClayW
              • Apr 2011
              • 377
              Originally posted by Stanley Rockafella
              gasoline
              To be clear, I'm asking about the tube on the far right/top.
              • slammin.e28
                שמע ישראל
                • 12054
                It's all part of the primitive emissions system.
                If there is a rupture in a hose, yes, as it carries fuel vapor from the fuel tank to the expansion tank.
                Also check that the gasket for the fuel sender and pump is in tact. My dad was getting fuel smell (in his e30) and it was because the gasket was bad. I think he reused it when he replaced the pump.
