Transmission Output Shaft Seal
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    My transmission's output shaft seal needs to be replaced again and I was curious if there is anything I need to do to the seal to make sure it is sealing properly. The seal I'm replacing is not that old but it seems like it just didn't sit in there right like it was loose. This new one seems like it will be a tighter fit but I want to make sure I'm installing it right so I don't have to go through this again.
  • RobertK
    • Jun 2005
    • 5864
    Has nobody ever done this before?
    • DaN
      • 1265
      Knock it in until its flush and straight. You sure the selector shaft seal isn't leaking too?
      • 65Matt
        • 172
        I thought my output shaft seal was leaking but it was the selector shaft seal leaking down on it. Tried to replace it anyway but couldnt get the damn nut off. Good luck!
        • PeaveyBassist
          • Sep 2004
          • 3511
          The selector rod shaft is a common place of leakage. It is above the output shaft on the driver's side. Check that.
          Will
          RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
          Welcome e30 (brilliantrot '90 325is) 12/23/06
          DaveCN = Old Man
          My signature picture was taken by ME! Not by anyone else!
          If people keep quoting me in their sig, I'm going to burn this motherfucker down.
          • AdamF 88iS
            • 2051
            I bet the spring plate on top of the tranny is leaking. Despite what the typical internet buzz is, this thing actually leaks more often than both of those seals.
            It's near the top rear, a little to the left side. Has 2 10mm bolts holding it on. Has 3 dome shaped portursions on it. Dealer sells an updated design.
            Adam Fogg- '88 M3
            Common sense- It's the new 'gifted'
