Speedo issue
  • KEVORM
    • Jul 2011
    • 237
    Speedo issue
    Got my car running today, its an 84e with an M20B25 and '89 harness. Tach works great but when the key is placed in the on position (1) the speedo goes straight to 80mph or so, then when the car is started it goes to 135mph or so and stays there. Any ideas? Only the blue and white plugs are in the back of the cluster. Thanks in advance.
    -Kevin
    84' 325i -> PRO3 #304
    Powered by Manntechnik
    Work in Progress Build Thread
    That sounds like a bad speedometer.
    • Gregs///M
      • Mar 2012
      • 2459
      Yup, most likely failed speedometer. I have a few extra if you need for the older clusters.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • James Crivellone
        Head Janitor
        • 6305
        Kevin that sounds like a bad cluster mainboard. Possibly a trace that is shorting to another.
        I know you probably did the wiring correctly so I won't even go down that road of diagnoses. The speedometer circuit it pretty simple, 2 wires that go to a reed sensor in the diff. Very simple circuit.
        If you can (or have not already) replace the cluster with a late model one (1 red SI light + Coding Plug) versus the unreliable early models (3 RED SI Lights, weird stick looking coding plug on the rear of the tachometer)
        --James
        • seatown88
          • 331
          --James
          Is it a direct swap?
          I'll try this for Kevin over the weekend and confirm a failed cluster or not. Thanks for all the input everyone!
          • Pipes
            • Aug 2012
            • 485
            What's the cutoff on early vs late? Can I put in a VDO cluster on my '91 if I started with a Motometer?
            1991 349is (wadded up)
            1984 Rabbit 2.0L16v swap (wife's)
            2003 LR Disco II (wife's)
            1993 MB 400SEL (son 1's)
            1980 MB 450SEL (son 2's)
            2004 KTM 525 EXC-R SM Sold:(
            • Gregs///M
              • Mar 2012
              • 2459
              Cut off is 1986. VDO and Motometer are interchangeable.
              www.BavRest.com
              My Feedback Thread
              Our Facebook!
