Other than having to supply a second spacer, is there any reason a momo hub adapter won't fit the '91 318is? Just want to be sure I'm not missing something before I order one.
318is steering wheel adapter
Which spacer is it that this needs? I have an M-Tech II wheel I want to put on my soon-to-be-non-bagged '91...Originally posted by dbgrubbsOther than having to supply a second spacer, is there any reason a momo hub adapter won't fit the '91 318is? Just want to be sure I'm not missing something before I order one.John in MD - 1991 318is
190k miles and still rolling!
Originally posted by ak96ssWhich spacer is it that this needs? I have an M-Tech II wheel I want to put on my soon-to-be-non-bagged '91...
OK even for a newbie thats one I havent heard....
I'm not so sure a M-Tech II wil fit...
I cant understand why on eart somebody would put a Air bagged wheel in a NON airbag car
BTW: If YOURS is a 91' then it should be a air baged equip'd car ;) Which a M///2 wheel is finesigpic
Wastedincome420@yahoo.com
CURRENT STOCK LIST:
00' e38 750iL HighLine=Highway Queen
92' e30 318 vert=Aint going anywhere
91' e34 535iM=Aint going anywhere
91' e34 525iA=For parts
92' e34 535iA=For parts
Originally posted by wastedincomeOK even for a newbie thats one I havent heard....
Uh, yeah - my 1991, which has an airbag, is soon not going to have an airbag. Thus, "...my soon-to-be-non-bagged '91."
Anyway, I was just curious if someone could point out the right spacer for this wheel to fit. Sorry if I wasn't clear.John in MD - 1991 318is
When you pull the stock wheel off, there is a spacer on the shaft directly behind the wheel. You need another of these to go on the shaft after the wheel. The shaft is a bit too long for a non airbag wheel if that makes sense. I actually went to the hardware store and got a bronze bushing that worked fine.Comment
Originally posted by dbgrubbsWhen you pull the stock wheel off, there is a spacer on the shaft directly behind the wheel. You need another of these to go on the shaft after the wheel. The shaft is a bit too long for a non airbag wheel if that makes sense. I actually went to the hardware store and got a bronze bushing that worked fine.
That is what I needed to know, thanks!John in MD - 1991 318is
