fuel pressure regulator reliability?
  • robvert
    • May 2011
    • 7
    would like your thoughts on this. I have EFI parts from a 318i that I plan to use to convert my 2002 to injection. I have the used fuel pressure regulator (which I'll check out of course before installing)... but I was wondering if they tend to go bad or are they normally trouble free?
    Could save me a hundred bucks... but not worth it if they are prone to go bad. After all I am buying things such as fuel pump/sender and fuel injectors all new.
    thanks
    The FPR is usually fairly reliable, but the diaphragm can fail or the FPR valve can leak. It is a 20'ish year old part, so I'd just replace it.
    • AndrewBird
      The Mad Scientist
      • 11898
      Why not try using it first, then if it doesn't work correctly, buy a new one? No point in buying parts if you don't need to.
      • robvert
        • May 2011
        • 7
        yep, as I said I will test it (i think it should be 3bar?)... was just curious if this item tends to be a commonly replaced item or not. You know how certain parts on certain cars have intregrity and they never seem to need replacing? That's all I'm wondering since I am not familiar with E30's.
