strange guagetry issue
  • NC325iC
    • Mar 2004
    • 6565
    the right turnsignal indicator seems to be illuminated all the time, not fully but just a little bit, it gets brighter when the brakes are applied and i think it gets a little brighter with speed as well.
    any clue as to what could cause this?
  • chuckybob
    • Aug 2004
    • 952
    100% guess, but cracked instrument panel letting light from the instrument cluster lights through
    : : 1984 318i : : PNW E30 Crew : : Sold!!
    Now becoming the R3vlimited Pro3 car
    http://www.r3vlimited.com/board/showthread.php?t=93780
    • Court M3
      • Jan 2004
      • 6713
      maybe bad turn signal relay?
      Continuous For Sale Thread
      323i s50
      • BENdashdash
        Tom is not my friend
        • Aug 2004
        • 2506
        Yeah, one of my turn signal indicators slightly illuminates when the brakes are pressed. My check panel brake light warning won't go away, I'm thinking this may be related. Anyone?
        • James Crivellone
          Head Janitor
          • 6302
          My car does this as well, its VERY dim but I can see it light up.
          Its simply power backfeeding into the blinker circuit.
          • NC325iC
            • Mar 2004
            • 6565
            every thing works find the check panel light shuts off with brakes applied its just kind of annoying. only happens with lights on, dont know if i said that or not. and its gotten alot brighter in the past few months
            • turnofftheradio
              • Apr 2005
              • 448
              I had that exact problem last week. found it was the right rear turn signal bulb holder. cleaned it and greased it, then re crimped it a bit so it holds the bulb tight. problem is gone
