87 325e parts for a 1991 318is
  • gregrego
    • Sep 2012
    • 22
    Hey guys came across a 325e 5 speed coupe, was damaged in an accident and written off. What parts can I use off this car for my 91 318is ? Is anything better? I know the engine can be used and built but I have no current plans to pull the m42.
    I can't think of anything off the ETA car that would be an improvement over what your 318is came with.
    • ELVA164
      • 4861
      ^ That said, almost all of the parts would be interchangeable aside from things like the steering column, bumpers/bumper trim, ECU, and a few other small things I'm forgetting. It can be awesome to have a car like that around for odd trim replacement/improvement and whatever else might come up if you had the space for it.
      • gregrego
        • Sep 2012
        • 22
        That's what I will be picking it up for, has a fairly clean black leather sport interior. I will use it to replace my worn out tan interior. So the rest of the car is essentially useless to me, that's good to know.
        thanks!
        • ELVA164
          • 4861
          Keep stuff like dashboard buttons, bulbs, small trim pieces, stuff like that. It'll almost definitely come in handy in the future.
          • gregrego
            • Sep 2012
            • 22
            OK. What about the rear diff? I'm reading the 325's diff makes the 318more fun?
            • Robotin
              • Jun 2011
              • 4471
              i belive you can use the m20 flywheel/clutch/pressure plate. IIRC.
              1989 325i SETA stroker [delphin] R3V'd 8/31/2011
              1989 325ix [zinnoberrot] $OLD
              1970 2002 [Nevada]
              Originally posted by Herr Faust Schinken
              guy must have slid into something that doesn't look like a car vs car hit
              Originally posted by ak-
              Must of slid into Rob
              • roguetoaster
                Biggus Tippus
                • 7829
                The diff in the E will make the 318 less fun, albeit more economical if you don't mind bicycle like acceleration.
                • gregrego
                  • Sep 2012
                  • 22
                  Haha no thanks!
                  • BenjaminButtton
                    • May 2012
                    • 275
                    Definitely not more fun! Haha just more economical. I was very close to swapping my open 4.10 out of mine in favor of a 3.73 LSD, but then I was in an accident. I wouldn't even consider going numerically lower than 3.73 on an M42. And an e would most likely have a 2.xx ratio I would think?
                    Early models do it better.
                    '86 Cosmos Sedan LS1
